It is currently Fri Aug 15, 2025 3:27 am
PostPosted: Fri Feb 13, 2015 12:38 pm
Hi
Need to drill the pegholes but the money center (the wife) says we cant afford a pillar drill
is a cordless drill ok ?
If so any tips on keeping it level
PostPosted: Fri Feb 13, 2015 12:55 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
use a square to align up 90 deg hole use undersized bit and have a backup piece of scrap wood clamped on headstock.(reduces splintering) Use reamer and carefully measure until you achieve perfect fit
These users thanked the author ernie for the post: Cablepuller (Fri Feb 13, 2015 1:28 pm)
PostPosted: Fri Feb 13, 2015 1:01 pm
Sure you can use a hand drill and a brad point drill -- but you also need to make the little fixture shown in this DIY video a square is not enough of a guide.
http://www.todayshomeowner.com/video/di ... lar-holes/
Ken Cierp
These users thanked the author kencierp for the post: Cablepuller (Fri Feb 13, 2015 7:11 pm)
PostPosted: Fri Feb 13, 2015 1:29 pm
Cheers ken .. good tip
PostPosted: Fri Feb 13, 2015 1:42 pm
Ernie Do you put the scrap on the top and drill from behind or does it not matter cheers
PostPosted: Sat Feb 14, 2015 5:51 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
I would drill from the top with an undersized bit, and have the scrap block firmly clamped to the back . In case of small splintering, hopefully the tuner will cover the splinter or reaming out the hole from the backside will hide most of it.
These users thanked the author ernie for the post: Cablepuller (Sun Feb 15, 2015 2:57 am)
PostPosted: Sat Feb 14, 2015 8:58 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I drill all the way through with a small diameter bit. Then I use that hole to guide the larger brad point bit halfway in from each side. No breakout. If the bit is sharp, there's usually no tearout on the entry either.
These users thanked the author bobgramann for the post: Cablepuller (Sun Feb 15, 2015 2:59 am)
PostPosted: Sat Feb 14, 2015 9:26 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
What is a pillar drill? Is this a Euro name for a drill press?
PostPosted: Sat Feb 14, 2015 9:28 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
This works really well if you are drilling 2 different diameters, Like a hole for the shaft and a larger one for the bushing of a tuner.
These users thanked the author johnparchem for the post: Cablepuller (Sun Feb 15, 2015 4:21 pm)
PostPosted: Sun Feb 15, 2015 2:59 am
Yes mike its a british name for drill press
PostPosted: Mon Feb 16, 2015 10:13 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Got it. :)
These users thanked the author Mike OMelia for the post: Cablepuller (Tue Feb 17, 2015 3:14 am)
PostPosted: Tue Feb 17, 2015 10:57 am
Last Name: Lee
Country: Wales U.K.
Alternatively, raid the nearest toy box. :shock:
These users thanked the author whiskywill for the post: Cablepuller (Tue Feb 17, 2015 11:08 am)
Users browsing this forum: Michaeldc and 15 guests
